*****Pavlock Performance Cam/Heads/Headers special******
PACKAGE 1:
Comp grind of your choice with Double springs, Titanium retainers, new valve seals, Chrome-Moly push rods, NGK TR-55 plugs, All new GM gaskets for the cam install, Professionally Dyno Tuned for only
1600.00!!
Package 2:
Everything Mentioned above as well as stage 2.5 heads flowing in the 310-315 CFM range with new GM head gaskets, NEW LS7 lifters and NEW lifter trays, GM head bolts, new water cross-over seals, and all front gaskets included in package 1, PB under drive with belts, all installed and Dyno tuned for only
3550.00!!
Package 3:
All packages combined adding Kooks stainless headers with off road pipe all installed for only
5150.00!!
Add:
100.00 for vettes
ported/polish and shimmed ls6 oil pump installed
160.00
If you go with an oil pump, timing chains are listed as following:
ls2 timing chain
35.00
Roll master single adjustable timing chain installed
105.00
Roll master double adjustable timing chain installed
115.oo
Deposits are required to reserve your spot in line and will depend on the package you go with. You can add or subtract to the package to best suite your needs. Hurry now and make an appointment!!
Bryan
