What cam to get
My advice on getting a cam is to do you own research. You know best about what you want from your car and what you are willing to live with. Get an idea of what size cam you want and then go from there.
Also do all of your supporting mods before camming the car.
You can keep your stock rockers, but not the springs, and i would reccomend replacing the pushrods. Also you should consider future plans for the engine, like if you will stay n/a or go boost or juice, as there are cams designed for each. What kind of driveability are you looking for, and since you have an auto, most cams are going to require a stall.
Get with who ever is doing your converter and talk cam specs with them. Where your cam makes it's power is going to effect how/where your converter flashes.
From the looks of things your taking it step by step which is good, but your looking at each part individually which is bad. Build you car as a whole. The combination of parts working together is greather then the individual parts added up. Buying all top parts means nothing if they don't compliment each other. Just look at the Olympic "Dream Team" when it had all the top NBA picks. They got beat by teams of unkowns that worked well together.
My advice is to slow down a reasearch the hell out of this before slapping a mix of good sounding parts together.
, and get a car with the engine created by god
himself.
