starting on my 6.0 project need input
Old Aug 23, 2008 | 10:56 AM
bigfatls6's Avatar
Default starting on my 6.0 project need input
I have a 6.0 iron short block That has low miles on it. It seems to be in good condition turns over really freely. I would like to get possibly new bearing installed along with some good rod bolts. You can still see the cross hatching in the cylinders. Not really sure what all I should do to to get it ready to be installed. what do you think it should cost to get new bearings and good rod bolts installed? I will also be installing the melings High out put oil pump. Do you guys recomend any one that can do this reasonable? If they are not a sponcer just send me a pm. If I need to have it honed and new rings installed I can do that also just didn't want to if it doesn't need it. Im not really looking to do a piston swap or any thing like that.
Old Aug 25, 2008 | 12:25 AM
bigfatls6's Avatar
No ones with any info to offer
Old Aug 25, 2008 | 12:38 AM
5w20's Avatar
if you want to install new bearings and rod bolts might as well go forged...
