Almost Done
Matt
Matt
Don't worry guys, though these two talk more **** back and forth than UT and aTm, if something was wrong on either car before a race they would both drop it in a heartbeat to help the other person out. That's racin!
Now stop being a vag john and spray that thing into the 9's so you can turn it back into a street car.
John btw with a flip of a switch you won't do **** from a roll.. Just an FYI.. 200 < 300 last I checked. It won't matter we popped that *** when you made 550rwhp with a 390whp Cam Only + 75shot car.
Anyway nothing you own could beat Matt's car on the freeway unless you finally got that 91.5mm Turbo put on your Camaro, because if not you're screwed. Hell your car is going to have trouble with me on pump gas even on the freeway. ..and I maybe going bigger on this rebuild
When the motor is done your going to have to flip that switch and hope your converter doesn't "lock up" and give you issues like it did against Mike
