Any Home AC Experts
Old Aug 31, 2008 | 01:29 AM
LS1x2's Avatar
Formerly 4mulaJoe
Default Any Home AC Experts
Our AC decided to stop working today. I decided to do some troubleshooting at midnight when I got home to see what might be the problem. I swapped the breaker for a separate 30 amp. I also replaced the batteries in the thermostat and tried hotwiring the compressor to come on, but no dice. The thermostat will click, but the outside unit will not come on. I also found that the heat will not turn on either. I don't know a lot about AC, but seems the only things the heat and AC have in common are power, thermostat, and the controller. I suspect the controller is bad. I'm hoping somebody on here might be able to give me something else to check. I will probably have to call an AC guy out tomorrow either way since I can't find a place to buy parts.
Old Aug 31, 2008 | 10:17 AM
rooster99ss's Avatar
yeah, most places won't sell you parts unless you're a contractor, i think it's BS. I don't know much about A/C, you've already checked everything i would think to check
Old Aug 31, 2008 | 10:27 AM
tollway bandit 1's Avatar
My condenser went out last month. The condenser is like the speed controll for the outside fan motor. Just a idea? This is how you can test this. Make sure your A/C is trying to come on, go outside to the unit and get a long screw driver to push on the fan blades. If you can give the fan motor a push start and it speeds up its the condenser that is bad.
Old Aug 31, 2008 | 10:42 AM
SLV_WS6's Avatar
Are you getting power all the way to the compressor? Check you're low voltage wires for power(thermostat wires at the out side unit) Check the power suply connections at the compressor. Check the contactor as well. I do commercial refrigeration and some residental. What part of town are you in?
Old Aug 31, 2008 | 10:46 AM
PhantomSS's Avatar
How old is your A/C I can help
Old Aug 31, 2008 | 01:10 PM
LS1x2's Avatar
Formerly 4mulaJoe
Ok. About 45 minutes after I posted this the AC came on and ran fine all night.
SLV_WS6,
I check all of the connections at the outside unit to make sure they were good, butI don't have a volt meter. I am near 290/hwy 6.
PhantomSS,
The unit is 6 yrs old.
I keep thinking this is a problem with the controller b/c neither the heat or AC will kick on.
Old Aug 31, 2008 | 03:45 PM
SLV_WS6's Avatar
Sounds like the compressor went out on overload. When the compressor get to hot it will shut off untill it cools down. If it happens again kill the power and put a bag of ice on the compressor. If it continues send me a pm and I can come check it out.
I WILL WORK FOR HOT ROD PARTS!!
Old Aug 31, 2008 | 05:13 PM
PhantomSS's Avatar
Sounds like SLV WS6 hit the nail on the head,might have him look at it before it gets $$$$$$$$$$$
Old Aug 31, 2008 | 07:23 PM
LS1x2's Avatar
Formerly 4mulaJoe
I'll do that. Would that explain the heater not being able to come on too?
Old Aug 31, 2008 | 07:26 PM
jt093's Avatar
Joe, I know a good AC guy. If you need his contact info give me a call or shoot me an email.
Old Sep 1, 2008 | 12:34 AM
BizZzatch350's Avatar
Moderator
You dont need a/c, weight reduction.
Old Sep 1, 2008 | 12:56 AM
jdmoore144's Avatar
They do that so stupid people dont try to work on their on unit. Most people who try to work on it screw up more than they did good. Also if you have a new unit and you do not have a liscenced company work on your unit than it will void the warranty.
Old Sep 1, 2008 | 12:58 AM
jdmoore144's Avatar
The condensor is the whole outside unit. You condensing fan motor went out which is totally different. What happens when that goes out your unit will kick off in high head. Basically overheats and shuts itself off.
Old Sep 1, 2008 | 01:04 AM
jdmoore144's Avatar
That would ususally be the problem but since his unit was not turning on during heat (unless he has a heat pump) then a good possibility since it is a newer unit that it might have a float switch on it. Which all depends on how the wired it. Also could be the circuit board not passing power the way it should be. Just an interment problem.
Note to anyone that thinks they should work on there AC unit themselves. DO not try to. You should have it serviced once a year in the spring to try to head off problems. Most companies do have specials for Spring Tune-ups. Make sure they wash out the condensing coil before they try to get pressure reading. If they dont tell them to leave.
Old Sep 1, 2008 | 11:37 AM
LS1x2's Avatar
Formerly 4mulaJoe
Well, I got lucky, and we were all wrong. It died again late last night. The only place I figured would come out on labor day was ARS.
It turns out the switch in the attic had a wire come loose. I paid an $80 service charge, and it is done. I re-attached the wire, but I'm going to pick up a new switch since some plastic fell off of that one.
Old Sep 1, 2008 | 03:45 PM
Moderator
You got lucky, a.c **** usually costs a ton. You could have pimped Jon out for his gymnastic skills but his dismounts were a little rough.
