where to put nozzle
Old Sep 5, 2008 | 06:26 PM
volcanic2345's Avatar
Default where to put nozzle
i got a wet kit but i dont think its hitting hard enough i got my nozzle right before the intake after the mass air but someone told me to bring back the nozzle to right after the mass air.... i know a dry kit you mount in the lid before mass air! but they said to put nozzle right after the mass air flow is this right??
Old Sep 5, 2008 | 06:38 PM
quickblade's Avatar
on a wet kit the nozzle should be located AFTER the MAF...
Dry kit is before the MAF......
Old Sep 5, 2008 | 06:40 PM
The Postman's Avatar
did you check your bottle pressure?
Old Sep 5, 2008 | 06:56 PM
quickblade's Avatar
http://www.fquick.com/garages/viewga...ewimg&id=89195
there is mine before the MAF..... as to where you should have yours after the MAF somewhere.....
Old Sep 5, 2008 | 08:01 PM
GoldRust's Avatar
LS1TECH Sponsor / 7 Second Club
Old Sep 6, 2008 | 12:39 AM
BizZzatch350's Avatar
Moderator
If you put the nozzle right before the air filter you don't need a nitrous filter because the air filter then works as a nitrous filter. Also a good idea to run the blown down tube up in to the cabin.
Old Sep 6, 2008 | 11:26 AM
LS1x2's Avatar
Formerly 4mulaJoe
More fun this way. Just make sure your n2o is medical grade.
Old Sep 6, 2008 | 01:10 PM
i know dry/wet is different i was talking about on a wet kit i had it in the bellow right before the intake i put it back a little and it hit a little harder bottle pressure about 950
Old Sep 6, 2008 | 01:51 PM
LS1x2's Avatar
Formerly 4mulaJoe
I don't think you will notice a difference. If you want it to hit hard, do a long purge or up the bottle pressure a bit.
Old Sep 6, 2008 | 01:58 PM
quickblade's Avatar
If you had it in the bellow... you should be good... now its going to be a matter of direction it is hitting at...
I would say check the angle of the nozzle, and make sure it is spraying right..
maybe check the noid.. spray it out to confirm it is hitting.
