Need Help Troubleshooting....
Old Sep 12, 2008 | 03:12 PM
02txceta's Avatar
Default Need Help Troubleshooting....
I have a 2 cylinder Onan 6.5 Genset Generator that powers my house when the electricity is out. Anyway, this thing is just like a car engine...runs off a battery, has a coil, starter, etc...it has not been started in about three years probably.
I put new plugs in it and has a good battery hooked to it, but will not turn over. It will try a very weak turnover and then just clicks like you would see when a battery is dead. The battery has full charge and know that is not the problem and has all new wires running to it.
My first thought was coil, but do not think it will do anything if the coil is bad...then started thinking starter...thoughts?
Old Sep 12, 2008 | 03:23 PM
The Postman's Avatar
starter is a good place to start...did you try just jumping it over at the starter and see what happens??....poss that the brushes got gummed up and just need to be cleaned a bit...could also be a relay going bad...idk man
Old Sep 13, 2008 | 01:29 AM
goober35's Avatar
Clean and check all of your connections and check and see if your battery cable is rotted out also makesure u have a good ground.
Old Sep 13, 2008 | 03:01 AM
01CaMMMaro's Avatar
did you put the key in the ignition?
