I need help ASAP!
Old Sep 14, 2008 | 11:44 PM
crazylarry88's Avatar
Default I need help ASAP!
When I go out to start my car today it would not start I tried to start it several times later it finally started. So now every time I go to start it does the same thing. Its like its not getting gas, I just went and got it tuned last friday could that be the problem? Or could it be bad gas? Or is there any way that water could have got into my motor some way? Also my service engine soon light came on have not gotten it looked at yet because everything is closed because this dam hurricane.
Old Sep 15, 2008 | 12:41 AM
Chhh Chhh's Avatar
get the code pulled were u low on gas? and check ur starter fuses under ur hood
Old Sep 15, 2008 | 01:27 AM
01CaMMMaro's Avatar
check engine light flashing? that would be a missfire if so, most likely a bad coil pack.
