Silly mustangs
Old Oct 6, 2008 | 06:43 PM
  #41
SlwBirdy's Avatar
Hell ya man. I will for sure.
Old Oct 6, 2008 | 07:47 PM
  #42
pennys58's Avatar
Great video! Car is sick
John
Old Oct 6, 2008 | 07:49 PM
  #43
Never_Enuff's Avatar
Originally Posted by babydeuce
Cheap shot there Matt
Jack
I know. Just playing....
Old Oct 6, 2008 | 07:52 PM
  #44
John
Thanks sir.
Old Oct 6, 2008 | 08:18 PM
  #45
Originally Posted by LS2 KLR
Link didn't work? Since I'm hoping for some good numbers soon, what's the specs on the car?
Right click save as. ITs a big file.
Combo is this:
Engine:
Stock Cast crank, used stock SVT rods, Probe pistons
stock 03 32v heads, with a Comp valve job and +1 intake and exhaust valves
ARP main studs, ARP head studs
Stock 03/04 cobra cams
Fuel/Induction:
Sullivan intake
BBK twin 65mm T/B
Cobra dual pumps
KB BAP
60 lb/hr injectors
Suspension:
Full QA1 tubular front suspension w/ coil overs
03/04 Cobra IRS with all upgrade poly and spherical bushings
MM tie rod kit
Steeda Rear springs
Drivetrain:
Stock 2002 4R70w Automatic
Lentech manual valvebody
TCI 3400-3600 stall
TCI deep pan
FRPP Aluminum Driveshaft
Now has 3.55 gears (did have 4.10s)
Stock ford Trac-loc
Stock 03/04 Axles (DSS level 5s waiting)
Power Adder:
Twin 57mm Turbo kit BY HP Performance
Manual Boost contoller set at 15psi right now.
Only have 13-14* of timing in it on the dyno...on colder IAT temps, more timing gets added...around the tune of 19*...so on the dyno it might be 607rwhp...on the street...well. You do the math on boost and degrees of timing.
Let me know if you need anything else guys!
Glad you guys like the video. Actually feel pretty good about myself on a LS board and they like it!
Matt
Old Oct 6, 2008 | 09:29 PM
  #46
SlwBirdy's Avatar
I had to get up and go pee before I got done reading your mod list.....
Old Oct 7, 2008 | 09:53 PM
  #47
^ Buahahahahaahahahaha!
Old Nov 5, 2008 | 01:58 PM
  #48
FANCHERFAST's Avatar
Originally Posted by SlwBirdy
Ya you to man. Best part about the f-bodys in the community. The stall should be here on thursday I think. Matt should be giving me a hand. And we will definitly be heading down there when its all up running.
trying to get ahold of you. cant send you a PM. whats up??
Old Nov 6, 2008 | 12:15 AM
  #49
Gold Z's Avatar
The Mustang is fast, it's the driver who is slow............j/k Matt.
Old Nov 6, 2008 | 12:26 AM
  #50
SSilverSSurfer's Avatar
bad *** video, original, and mad props on the build. looks good and runs strong
Old Nov 6, 2008 | 01:28 AM
  #51
5w20's Avatar
nice build and great video
Old Nov 6, 2008 | 04:45 PM
  #52
Sarge_13's Avatar
Umm...he's banned.
