Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
used air compressor problems
Old Nov 8, 2008 | 05:43 PM
MUSTANGBRKR02's Avatar
Question used air compressor problems
I bought a 5hp 60g Devilbiss air compressor recently. After wiring it and plugging it in. I cannot get it to start on the switch. I have to turn the breaker on and off. Every few times there is a nice blue spark too. Anyone have any ideas?
Bill
Old Nov 9, 2008 | 12:01 AM
MikeGyver's Avatar
Bad start capacitor?
Old Nov 9, 2008 | 10:38 AM
Old Geezer's Avatar
As Mike said.. Start cap?
Also, the pressure sw on most "home style" compressors handle the hi amp loads, directly, Furthermore, the motors are not exactly the best Q.
My recent experience:
A NEW 5hp/80 g.
Ran for about 3 mo's, and blew the breaker.
Pulled the wire connection cover, and found 1 of the motor leads, a cheapass 1/4" push on, had melted.
Found that the contacts in the pressure sw were toasted, too.
The cure:
1. Added a remote contactor from Grainger,[80A], triggered by the pressure sw.[Also, a new press sw.] This unloaded the sw., and put the hi amp startup load on the remote. [Startup loads can be 4-6X running amps.]
2. Cut off the cheapass 1/4" connectors, and used wire nuts on the connections.
I'd check the pressure sw, and the check valve in the top of the tank. If the check valve sticks, the motor will try to start under load..In this condition, the motor, contacts, wiring, won't last long!
