Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Electric impact and pulling wheelstuds?
Old Jan 28, 2009 | 10:35 AM
joblo1978's Avatar
Default Electric impact and pulling wheelstuds?
Which electric impact can do this?
I need to swap out my wheels studs for some shorter ones and am looking for an electric impact to do this, and make future wheels changes easier and less painful on the back.
What do you guys recommend?
Thanks!
Old Jan 28, 2009 | 10:36 AM
Benner's Avatar
Why are you using an impact. Hammer to knock them out and I believe you can use a hammer to tap them back in as well.
Old Jan 28, 2009 | 10:57 AM
00_STANG_KILLER's Avatar
I have a snap on electric impact and it works very good but i dont think it could pull a wheel stud back through i have always used my snap on air impact. The rears you can use a hammer on since you have to pull the axles (if using arp wheel studs b/c there longer) the front will take a installer to replace them once removed. There are wheel stud installers but a old lugnut and big nut work for me.
Old Jan 28, 2009 | 09:56 PM
budhayes3's Avatar
PT's Slowest Truck
I don't believe that my DeWalt 18v 1/2" impact gun could pull wheel studs all of the way through a hub, but I've never tried.
Old Jan 29, 2009 | 09:58 PM
johnson73801's Avatar
most wheel studs will install easily ...my cheap airgun($20) that my lil sis bought me has enough power to pull a wheel stud.i have an installer made by lisle that helps make the job easier and you dont mess anything up.
Old Feb 17, 2009 | 09:10 PM
metalic03's Avatar
I build metal buildings for a living and use dewalts 1/2 electric impact. It is very stout and will for sure get the job done! price is about 120 bucks.
Old Feb 18, 2009 | 07:50 PM
pmbmax's Avatar
Not battery electric I have a Black and decker professional it has like 250 ftlb
Old Feb 22, 2009 | 09:45 AM
subarubill96's Avatar
i use my trusty crapsman pro 1/2" drive 8.5 amp impact , never had an issue with sucking in a wheel stud to date. i just use like 12 1/2" flat washers and an old lug nut with a copper "flute" insert i made so i dont mess up the threads.
i use a 2lb sledge after ive soaked the stud in PB for about 20 minutes with great results
