Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
valve spring compressor
Old Feb 23, 2009 | 04:15 PM
Nads06111's Avatar
Default valve spring compressor
Where is the best (cheapest) place to get the crane valve spring compressor?
Old Feb 24, 2009 | 10:43 AM
01ssreda4's Avatar
get the tims foo..
Old Feb 24, 2009 | 02:05 PM
99_SS_LS1's Avatar
Originally Posted by 01ssreda4
get the tims foo..
+1
Old Mar 13, 2009 | 01:03 AM
bowtieguy04's Avatar
Default make your own valve spring compressor
buy one those pry bars with the flat end on one side and the curled part on the other, there like five bucks. and gring the v slot on the flat end to fit your rocker stud. there is an tear drop shape in the middle about an inch down from that. grind that out so the valve stem fits in the hole but the bar still presses the valve spring down. now but som rubber coating dipp. (the stuff you can dipp the handles of your tools in sell at walmart) then put the end under your rocker stud(without the rocker on it) and place the tear drop shaped hole you drilled out over the spring and press down. you can do this with your heads on the engine if you put some compressed air in to the cylinder your working on. i'll put picks up if i can ever find the one i made. if not ill do a step by step on it.
Old Mar 13, 2009 | 09:28 AM
mrhzk35404's Avatar
Well, you better buy one quick if you can with crane going out of business who knows it anyone will keep making that tool. Oh and I bought the tims tool.
