Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Air moving products compressor missing a part
Old Mar 2, 2009 | 08:05 PM
gs1000's Avatar
Default Air moving products compressor missing a part
Hello all, I to have an Air Moving Products Air compressor. It is a 120 gallon tank, A 10 horse motor and a large two stage V-twin compressor. Upon purchase the previous owner stated the big tube had been damaged in moving it across the shop. (no big deal) The other part I noticed after purchase was what appears to be a line missing from the inlet of the tank for the compressed air and the other end appears to go to the end of the crankshaft area of the compressor. There is a .125 steel rod that sticks out of this area. it is spring loaded. It would appear that the line diverts air pressure to the end of the crankshaft end cap housing. I don't know and can't seem to find out if there should be some sort of oiling device that is air assisted or what the air pressure to this fitting would do. I don't dare run the compressor until I have this situation repaired. I can't locate the original company by any form of Internet search, and the local air compressor shops don't want to give me the time of day. Any information would be greatly appreciated. thanks again.
Stephen
Old Mar 2, 2009 | 08:46 PM
Camaroholic's Avatar
Can you post any pictures? Pictures are worth 1000 words in this situation.
Old Mar 7, 2009 | 11:06 AM
Jeff Smith's Avatar
No pic won't help...
