Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
large water passage plug
Old Mar 14, 2009 | 05:52 PM
forcd ind's Avatar
Default large water passage plug
i needed to itstall the large screw in plug in the engines water passage-it meas. 11/16", of course i didnt have an allen wrench that size, so i looked around the garage for something i could make-got a 7/16 bolt, and it used an 11/16 o/d nut, so i welded the nut onto the bolt, fit perfect, cured the problem, took all of about 1 min to make, lol
Old Mar 14, 2009 | 09:21 PM
99345hp's Avatar
Ive done this several times. It works really well if you have a tight space to get into also.
Old Mar 30, 2009 | 10:18 AM
TJ's Avatar
TJ
thats good stuff!!
