Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
HELP-Hypertherm VS thermal dynamics plasma
Old Sep 24, 2009 | 09:29 AM
brian g's Avatar
Default HELP-Hypertherm VS thermal dynamics plasma
issue, I cannot decied which plasma cutter to purchase.
Anyone here with any words of wisdom?
Help?
1st choice
Thermal Dynamics Cutmaster 39 Plasma Cutter
http://store.weldersource.com/13830.html
pros- cuts up to 5/8th, 4 yr power supply warranty
cons- weighs in at 40 lbs
2nd choice
Hypertherm Powermax30 Plasma Cutter
http://store.weldersource.com/088003.html
cons- only 3 yr power supply warranty, only cuts up to 3/8
pros- weighs 20lbs and has a good reputation
Any sage words of advice before I break the bank?
TIA
Old Sep 24, 2009 | 06:31 PM
Camaroholic's Avatar
Well, I have a Powermax 45, and it cuts superbly. I've cut a lot of stuff with it, and am still on the original tip that came with it. I've cut 5/8" with it easily (I'd bet the 30 would do 1/2"). Paint me in the "Hypertherm Fanboy" camp. I think you'd be pleased with it. The 45 cuts great for such a physically small machine, I'm sure the 30 has a similar impact.
And buy a GOOD filter - the Motorguard M-60 comes highly recommended - right before the inlet to the plasma. Water and trash in the line is one of the leading killers of plasma cutter tips. Spend some $$ on filtering your air and you'll have no trouble at all with the cutter. If your air line has ever spit water at you, you MUST get additional filtering.
Old Sep 24, 2009 | 09:30 PM
jman54002's Avatar
hypertherm hands down...there is nothing better
Old Sep 25, 2009 | 09:43 PM
brian g's Avatar
Hhhhhmmmm, I think we may have a winner?
Thaks for the input fella's!
Old Sep 26, 2009 | 04:18 PM
METAL MAN's Avatar
I have been using TD machines for about 11 years now and had zero issues with them. As with welding machines you should always buy the most power you can afford cause you'll always want more. Power, power, power!!
