Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Keeping engine up without k-member?
Old Dec 9, 2003 | 12:08 PM
quickWS6's Avatar
Default Keeping engine up without k-member?
What is the best way to hold an engine up without the k-member? I've pulled the k-member before and just used a jack on the oil pan, but I have been thinking about changing the rod bolts now. What is the best way to keep the engine up while doing this without an engine hoist? Is it possible to remove the oil pan with a tubular k-member and install the bolts then? Thanks for any ideas!
Old Dec 9, 2003 | 12:41 PM
Ackattack1's Avatar
Without a hoist it's going to be pretty tough to do. It may be easier to just drop the whole engine while your at it...especially if you're installing a new TC at the same time. Just a thought.
Old Dec 9, 2003 | 07:34 PM
Damian's Avatar
LSX Mechanic
There are motor hoists that bolt to the shock towers, and keep the entire motor stable when dropping the K-member. They are very pricey, but do the trick.
josh
Old Dec 9, 2003 | 09:02 PM
wrencher's Avatar
wrencher
There are engine support fixtures, there not to pricey.
OTC makes a nice one (there expensive as tools go) for around $200.
4324 is the part # for the one that work for LS1 cars.
go to www.otctools.com & check it out.
They have another one that is better than this one , dont have the part # though.
