Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
question for 4 post lift users
Old Dec 1, 2010 | 11:11 PM
25thhawk's Avatar
Default question for 4 post lift users
When you lower the lift all the way down, does it go all the way to the floor? I just finished installing a Bendpak in my garage and when fully lowered, the cables are still tight and the rails are 2 inches off the ground. Almost seems like the cables are too short.
Old Dec 1, 2010 | 11:15 PM
gearhead 69's Avatar
u aught to have some slack under the ramps were the lines run under them i had the same problem with one.just raise it up an u awta see.
Old Dec 1, 2010 | 11:35 PM
25thhawk's Avatar
not sure that I understand. The cables never lose any tension. There is nothing that runs below the ramps or crossmembers. It all runs inside them and cant get caught. It just seems like the ram is fully extended, but lift doesn't make it to the floor
Old Dec 22, 2010 | 11:04 AM
Competition GT's Avatar
That doesn't sound right at all. I have 4 bendpak lifts and all of them (including the 4 posts) have slack past even with the ramp on the floor.
