Torque Wrench Question
There are a number of things to consider when using a torque
wrench. The “friction factor” changes from one cycle to the next.
That is, friction is at its highest value when the fastener is first
tightened. Each subsequent time the fastener is torqued and loosened,
the amount of friction lessens. Eventually the friction levels
out and becomes fairly consistent for all following repetitions.
Three basic elements that contribute to the friction factor:
1. Most importantly -The fastener assembly lubricant
2. The condition of the receiving threads
3. The surface finish of the fastener
Because of these variables, a phenomenon known as “preload
scatter” or preload error occurs. This is basically the difference
between the amount of preload achieved on the first installation
of the fastener and the amount of preload achieved on subsequent
torque/loosen/re-torque cycles. It’s not uncommon to see “preload
scatter” in the range of 4,000-8,000 pounds between the first and
tenth pull on a new fastener depending on the lubricant used.
I wouldn't suspect the wrench first, like the great post above noted, there are many variables to take into consideration and any of them can heavily impact the final torque.
Great topic.
what we do is torque wait 5 mins. then re-torque (if the bolt moved, wait another 5 mins and re-torque we do this process until the bolt no longer moves)
Also as noted above- proper lubricant
