Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Adding outlet for welder
Old Mar 19, 2011 | 01:31 PM
ATX-Iroc's Avatar
Default Adding outlet for welder
Im going to be using a miller 175 mig. I have room in the box and my question is what wire do i need to use. It uses a 3 prong cord so do i need wire with 2 insulated hots and a bare ground or 2 insulated hots an insulated neutral and a bare ground. 10 gauge is correct for use with a 30a braker right.
Old Mar 20, 2011 | 08:30 PM
hawiianpwr's Avatar
Just looked it up and it pulls 19.5 amps at 230 volts. So your good to use #10 wire with a 30 amp 2-pole breaker. Pull 2 #10 hots(one black, one red) and a #10 ground(green).
Hope that helps.
http://www.millerwelds.com/products/...ermatic175.pdf
Old Mar 21, 2011 | 12:03 AM
ATX-Iroc's Avatar
I ended up using 10-2 wire. its fine to have the bare ground right.
Old Mar 21, 2011 | 05:43 AM
hawiianpwr's Avatar
Yep your good
