Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Need bolts for engine on engine stand
Old Mar 26, 2011 | 08:32 AM
Billiumss's Avatar
Question Need bolts for engine on engine stand
Hi Guys,
I am going to be putting a LS engine on a engine stand but what bolts do I use?
What size and grade?
Thanks,
Bill
Old Mar 30, 2011 | 03:32 PM
Billiumss's Avatar
Either no one has never put a LS engine on a engine stand before or this is the wrong section to get answers???
Old Mar 30, 2011 | 10:59 PM
Oldsmobility85's Avatar
I have some bolts in my toolbox ill measure up for you tomorrow evening. I think they are 10mmx1.5 but not positive. I am pretty sure though.
Old Mar 31, 2011 | 12:00 PM
Rubrburnr's Avatar
I believe they are 100mm long as well....
Old Apr 5, 2011 | 06:10 PM
bww3588's Avatar
M10X1.5
i got them about 3 inches long and stacked up washers to make up the difference. i didnt feel like buying 3 different lengths of 4 bolts, so i just bought them long and found some washers in the tool box.
Old Apr 7, 2011 | 12:14 AM
01ssreda4's Avatar
You use the size/type of the bellhousing bolts. I measured a bellhousing bolt length, then measured the round collar length on the mounting points of the engine stand, added the 2 measurements together, then went and bought bolts as close to that length as possible from Home Depot. Get the best grade they have available.
