Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
PlastiDip on jack stands?
Old May 19, 2012 | 11:00 AM
Stu_x24x's Avatar
Default PlastiDip on jack stands?
I've seen those plastic top covers for jack stands and was curious if something like PlastiDip could be used on the stands instead. I'm just looking for something to help with grip and help prevent scratching things up under there. Thoughts?
Old May 19, 2012 | 12:26 PM
Pseudonym's Avatar
My friend did it. He only did one coat and it just kind of came off after the first use. I guess if you put multiple coats on, it might work.
Old May 19, 2012 | 01:33 PM
jetsbaby's Avatar
Harbour freight sells them for cheap..
Old May 20, 2012 | 04:02 PM
Stu_x24x's Avatar
I guess I might as well try the PlastiDip to see...and if it doesn't work out I can swing by HF to snag some up. Thanks
Old May 20, 2012 | 04:33 PM
Blasko's Avatar
I think no matter how thick you apply plasti-dip, it will wear off. I usually just grab some cardboard or something and stick between.
Old May 20, 2012 | 06:58 PM
Mike52's Avatar
Folded shop rags works for me.
Old Jun 9, 2012 | 07:41 AM
01350ss's Avatar
another method is those rubber disks that some people use to grip the top of a jar to help them spin it off
Old Jun 13, 2012 | 05:06 PM
WheelsUp84z's Avatar
The roll on or dip types of the plasti-dip would work. the paint/aerosol style probably wont hold up to contact.
Old Jun 14, 2012 | 03:58 PM
bigbadblack93z's Avatar
try the spray on duplicolor bed liner and avoid the plastidip, either one will still flake off after a time or 2 though.
Old Jun 14, 2012 | 04:59 PM
chasgiv3's Avatar
I just use shop rags myself. The Harbor freight ones will work if you want to get fancy.
http://www.harborfreight.com/2-piece...and-95952.html
Old Jul 10, 2012 | 02:17 PM
NEXRACE's Avatar
x2 on the shop rags, quick & easy, i'll get around to the harbor freight ones some day, lol
Old Jul 13, 2012 | 12:46 PM
btlegacy's Avatar
shop rags or old tool box foam or anything rubber basically around the shop
Old Jul 15, 2012 | 02:46 AM
99Bluz28's Avatar
Just get some Prothane urethane Jack Stand Pads and a jack pad, that's what I've been using for yrs.
Old Jul 26, 2012 | 02:35 PM
Jim Shoulders's Avatar
I use some old thick astroturf on the floorjack pad and wrap the candlestick tops with astroturf and tie it on with safety wire or zipties . Works well and last a decent length of time. Hockey Pucks work well for low dollar motor/mount pads and jacking/jackstand pads if you have the style with large flat tops. They can slide on the jackstand application.
Old Jul 26, 2012 | 03:31 PM
Mr. Hyde's Avatar
Just drive it up on the curb like my neighbors. No need for a pesky jack or stands in that case.
Old Jul 26, 2012 | 11:48 PM
shayanaz's Avatar
plasti dip peels off
