Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
First time tig, need some help
Old Jan 29, 2013 | 10:30 AM
dragrex's Avatar
Default First time tig, need some help
I have the eastwood tig200, I can put down beads on flat metal, but when I go to weld 2 pipes togeather it's just not working, any tips or suggestions? Thanks
Old Jan 30, 2013 | 05:54 PM
CTSmechanic's Avatar
post pics..its easier to help you if we see whats going on
Old Jan 31, 2013 | 01:45 PM
Koondog's Avatar
Whats happening? Is it blowing open?. There are many factors that come into welding. Is it flux core? Shielded Gas? Steel or aluminum? Etc...
Old Feb 1, 2013 | 03:41 PM
k_cash1432's Avatar
Tig welding... Post a few pic so we know what its doing. Allot of it is practice. I have the eastwood welder as well and i havent had much playtime with it but im still learning how to weld two pieces of aluminup piping together. If i had more time to play with it im sure i would have it and walking the cup down but just havent had enough time. make sure you gas is set at the correct flow and your heat is correct. just takes time...
Old Feb 2, 2013 | 06:22 PM
NHRATRANSAM64's Avatar
There's definitely alot more information needed. Pics would help alot as well.
I am guessing you are going from thick gauge flat stock steel and moving to a thin wall tubing and blowing holes into it for a few reasons:
Amperage set too high.
Incorrect Polarity (pipe could be aluminum)
Inadequate tube preparation (if it is aluminized pipe, welding over it without prep gets ugly)
I'm in for some updates.
