Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Cam degree kit
Old Apr 27, 2004 | 01:07 AM
66ImpalaLT1's Avatar
Default Cam degree kit
I'm going to order a cam degree kit (wheel, dial indicator, springs) soon, is there anything different about the LS1 that I need to be aware of when ordering one?
Thanks,
Eric
Old Apr 27, 2004 | 10:07 AM
robertbartsch's Avatar
...not really anything different about the LS1 except they are aluminum and setting up a dial indicator using a magnet holder is more difficult.
I'm looking at Jegs.com - they have several different kits and prices. Some are specifically designed for cam installation without head removal that you might consider.
Old Apr 27, 2004 | 10:55 AM
HellOnWeelz's Avatar
You can buy one that screws into the valve cover bolt hole instead of using the magnetic base. But the LS1 uses metric valve cover bolts so keep that in mind. I bought one from ebay and had to weld on a bolt that would fit. But it works great.
Old Apr 28, 2004 | 09:23 PM
wrencher's Avatar
wrencher
I use a vice grip based dail indicator.
It is infinitely adjustable to fit what ever, + has many more uses other than degreeing cams.
