Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Welding with a generator?
Old Sep 5, 2013 | 10:14 PM
oerllikon's Avatar
Default Welding with a generator?
Hey folks,
I have a question about welding with a generator. Im planning on getting a generator with a 240v outlet, since the garage that I keep my Z32 in only has one 120v outlet. I will probably be using a stick welder, since theyre cheap, and theyre what I weld best with. (poor college student..) Any advice/input?
I know you fellas have been around the block before
Thanks!
Old Sep 8, 2013 | 11:35 AM
Jimbo1367's Avatar
I was planning on doing the same thing. (Same reason)
Old Sep 16, 2013 | 12:42 AM
racerfox's Avatar
depends on how much you want to spend if your just stick welding aka smaw welding you can get a cheap 110 buzz box for not a bad price
Old Sep 25, 2013 | 12:40 PM
xxtremes33's Avatar
it really depends on the type of metal you plan on welding and the thickness. a simple 110v wire feed mig welder will be good enough for most jobs.
Old Sep 28, 2013 | 07:29 PM
Jimbo1367's Avatar
Milermater 211 MPV AND welding 1/4-3/8 "
Old Sep 28, 2013 | 07:41 PM
Fast86z's Avatar
I've welded plenty of 1/4" with my 110 stick. Just v-grove it and make multiple passes. I bought a $100 dc inverter welder when I was in college and you wouldn't believe all the junk i've welded with it. Built multiple work benches, frames, exhaust, even a motorbicycle. JMO, never used a generator.
