Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Wolfe 6 Point install
Old Apr 18, 2014 | 06:46 AM
silversrtman's Avatar
Default Wolfe 6 Point install
Just a quick question for anyone thats installed a cage before. What did you do about the body seam filler where the support plates go? I obviously cant weld over it. I was thinking about just tacking the plates in place and then taking the plates off and welding them together and then welding around the filler? I dont want to have a leak or anything if I take out the filler? Any advice on that or any advice in general would be greatly appreciated. Wolfe does a great job on making the install super easy with the jig notching, but this will be my first time putting a cage in a car. Thanks!
Old Apr 18, 2014 | 08:49 AM
ZeeTwentyFate's Avatar
scrape it off, weld it solid then get some more seam filler and re fill it. you shouldnt get any leaks though.
