Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
turbo to supercharger conversion
Old Oct 20, 2014 | 04:31 PM
racinea64's Avatar
Default turbo to supercharger conversion
Hey everyone
I need some help from those more experience then me. I've startet an experiment i guess you could call it I'm converting a turbo to a belt drive much like a pro charger but if it works I will be making kits to convert any turbo to a belt drive supercharger however I need a gear box that has at least a 1:10 ratio. I am making the box from scratch out of 2 in thick aluminum which Is at the machine shop as we speak the only thing that is holding me up atm is the gears I need someone to explane to me how to buy gears. I need one that had 120 teeth and another that has 12 teeth but I don't want to buy two gears and find out they won't work together when I get them how do I tell if the gears will mesh when I'm buying them. Pictures comming soon
Old Oct 20, 2014 | 06:29 PM
AKAFRED's Avatar
you may want more than 12 teeth on the small gear, i don't think it would live too long with that few teeth.
i would think that this wouldn't be worth the effort.
Old Oct 21, 2014 | 08:22 AM
racinea64's Avatar
Well I don't want to go with a full Turbo system I but a wiend is way out of my price range and I've always been fascinated with pro chargers and I have a full machine shoo at my desposal so I figured I'd try and make a conversion which is cost effective and I thought it would be a much cheeper alternative I did however find that the smallest gear I can get is a 24 tooth which should stand up a little better and I've also changed my designs from a single gear set to a double which will get me the same if not more rpms at the cluster of a little gear noise.
Old Oct 22, 2014 | 12:04 AM
Blown06's Avatar
8 Second Truck Club
Buy a procharger.
You'll have plenty of stuff to fabricate and work on to get it to work at full potential. Trust me.
Old Oct 22, 2014 | 12:18 PM
honda_head's Avatar
There isn't much difference in parts going from a complete turbo kit to a proper procharger kit... if you have a turbo, build a good turbo kit around it. if thats not what you want then sell it and get a procharger kit.
