Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
About to pull the trigger on a MaxJax
Old Dec 2, 2014 | 09:12 AM
oscs's Avatar
Originally Posted by blackbyrd
Thanks for the heads up oscs i appreciate it, still debating i guess
No worries. I still think you will like it. The 45" is plenty of room.
Old Dec 2, 2014 | 10:24 AM
blackbyrd's Avatar
now its more of a question of which one will fit better in the space i want to put it. my main problem is the return air duct work being right over the work area. one piece in particular only allows for 76" of vertical clearance, which is okay I think as long as I pull it on the lift nose first. For ease of work tough i would prefer to have it it backed into the this area. the scissor lift would allow me to scoot closer to the wall and clear the duct work it raises up to 53" but also doesnt have the same access underneath, and may require me to lift the car to clear the 5 3/4 inch frame of the lift.
my other option which would work for either is to put it in another area of the garage (its an odd layout) where height isnt an issue at all, but putting it there would impede on the way i use my garage if i did extended projects which one of them is going to be. also im not sure the slab thickness either so thats another concern
Its good to have options i guess, its just hell deciding
Attached Thumbnails About to pull the trigger on a MaxJax-img_20140925_160226598.jpg
Old Dec 2, 2014 | 11:43 AM
oscs's Avatar
now its more of a question of which one will fit better in the space i want to put it. my main problem is the return air duct work being right over the work area. one piece in particular only allows for 76" of vertical clearance, which is okay I think as long as I pull it on the lift nose first. For ease of work tough i would prefer to have it it backed into the this area. the scissor lift would allow me to scoot closer to the wall and clear the duct work it raises up to 53" but also doesnt have the same access underneath, and may require me to lift the car to clear the 5 3/4 inch frame of the lift. my other option which would work for either is to put it in another area of the garage (its an odd layout) where height isnt an issue at all, but putting it there would impede on the way i use my garage if i did extended projects which one of them is going to be. also im not sure the slab thickness either so thats another concern Its good to have options i guess, its just hell deciding
If it where me I'd just move that air duct elsewhere. I had to move my garage door opener 4ft to the right in order to make my setup work.
Old Dec 2, 2014 | 12:58 PM
blackbyrd's Avatar
i actually talked about that with a buddy of mine, the bulk of it is actually fine its just that 90 degree bend upwards that is the issue which could be routed to attach to the side of the main duct instead of coming into the bottom, that's about the only change that can be made with out redoing the entire system. if that piece were higher up i would gain nearly a foot of height i think.
I'm not sure why im debating it honestly because the maxjax is way better in terms of storage and clearance (getting the arms under the car) just gotta check the slab depth
Old Dec 2, 2014 | 01:11 PM
oscs's Avatar
i actually talked about that with a buddy of mine, the bulk of it is actually fine its just that 90 degree bend upwards that is the issue which could be routed to attach to the side of the main duct instead of coming into the bottom, that's about the only change that can be made with out redoing the entire system. if that piece were higher up i would gain nearly a foot of height i think. I'm not sure why im debating it honestly because the maxjax is way better in terms of storage and clearance (getting the arms under the car) just gotta check the slab depth
There is always a compromise unfortunately but such is life. I think the min. Is 4"
Old Dec 2, 2014 | 01:17 PM
black06g85's Avatar
been waiting for a good review of this, was planning on pouring a new floor and getting one in the spring, now I definitely am
Old Dec 2, 2014 | 01:26 PM
smitty2919's Avatar
What is the minimum slab depth for this to bolt to?
blackbyrd's Avatar
Thanks for all the input OSCS, i appreciate it
if its 4" i am golden, for some reason 6" was the number stuck in my head I'll find it later
Old Dec 2, 2014 | 01:49 PM
oscs's Avatar
Thanks for all the input OSCS, i appreciate it if its 4" i am golden, for some reason 6" was the number stuck in my head I'll find it later
No worries
oscs's Avatar
4" min
Old Dec 2, 2014 | 06:49 PM
JustAFooL's Avatar
6" would be pretty odd for a basement slab. 4" is the average and I doubt anyone would drop nearly double the price of the concrete unless it was requested. Take a masonry drill bit and drill into one of the saw joints of the concrete to check the depth.
Typical concrete is also 3000psi strength. I don't see any problems using this if it was even a little less than 4"
Old Dec 9, 2014 | 01:11 PM
  #32
blackbyrd's Avatar
I have seen the thickness as there was a full bathroom in the basement i took out over the summer. Dipshits busted out the concrete to attach some of the plumbing but didnt fill the hole back up afterwards. Some odd things in this house.
found out i cant put this thing where i want to anyway so this project is on hold. I would need to get the base post really close to an exterior wall for it to work ( like putting it in a narrow single car garage close)
oh well
Old Dec 10, 2014 | 06:30 AM
  #33
oscs's Avatar
I have seen the thickness as there was a full bathroom in the basement i took out over the summer. Dipshits busted out the concrete to attach some of the plumbing but didnt fill the hole back up afterwards. Some odd things in this house. found out i cant put this thing where i want to anyway so this project is on hold. I would need to get the base post really close to an exterior wall for it to work ( like putting it in a narrow single car garage close) oh well
That sucks
Old Dec 11, 2014 | 07:19 PM
  #34
oscs's Avatar
Got the truck adapters on there today. It puts my frame rails about 49" off the ground as my lift points are about 2-3" higher than my frame rails. I gotta say it is the perfect height. I don't even have to lean back anymore. Super pleased. Figure I'd throw a little update out there.
Old Dec 20, 2014 | 01:34 PM
  #35
SWEET98SS's Avatar
I have the maxx jax, best thing I ever bought. I have 10 foot ceilings in my garage. The only thing with the maxx jax is if you buy a tranny jack, it has to be a two stage, the singles wont fit under the car. Same with an oil catch, you need one that will fit under the car. My lift paid for itself in a year, I have older cars though.
Attached Thumbnails About to pull the trigger on a MaxJax-2011-november-december-260.jpg
