Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
epoxy flooring in garage
Old Oct 3, 2015 | 03:03 AM
Jake75's Avatar
Default epoxy flooring in garage
Anyone have their garage floor epoxied? If so what brand did you go with and how is it holding up? One coat or multiple coats?
Old Oct 4, 2015 | 12:35 AM
Blown06's Avatar
8 Second Truck Club
I did and I paid out the *** for it. Do it yourself.
Old Oct 4, 2015 | 01:17 AM
Jake75's Avatar
Yea i'm planning on doing it myself. I'm having a new home built and wanna put the epoxy before i start any projects and screw up the fresh concrete.
Do you know what they used on your floor brand wise?
Old Oct 4, 2015 | 01:40 AM
t_raven's Avatar
There is a lot of info on garagejournal.com about all kinds of floor coatings.
The absolute best is epoxy top coated with a urethane clear coat. Epoxy by itself will almost always lift off in spots due to hot tires. (Of course with any coating, prep is everything)
Legacy industrial is one of the sponsors on gj. This is their garage epoxy kit. The urethane is extra and the choices are in one of the drop downs on the side.
http://www.legacyindustrial.net/prod...00-sq-ft..html
Rust bullet has also been popular and is very durable. It's a one step product, so it's easier to apply, but for whatever reason it's not really cheaper than using epoxy and urethane. You also have a lot more color options for epoxy and if you like the wet look you can get it with epoxy and a clear coat.
This is from a thread on gj. It's Legacy epoxy and urethane. I like the wet look of it. He said it's held up very well and he even had some brake fluid spilled on it over night and it wiped up with no damage to the coating.
Old Oct 4, 2015 | 04:42 AM
Jake75's Avatar
This is from a thread on gj. It's Legacy epoxy and urethane. I like the wet look of it. He said it's help up very well and he even had some brake fluid spilled on it over night and it wiped up with no damage to the coating.
Very nice thank you for the link u will look into it
Old Oct 11, 2015 | 02:16 PM
aknovaman's Avatar
Rocks and gravel in tire tread is the death of epoxy floors.
