Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
ECM and Trans Control Module
Old Feb 26, 2019 | 12:29 PM
RedRascal's Avatar
Default ECM and Trans Control Module
I am installing a 2007 5.3L LS donor engine into my truck project. Does anyone have any idea if there exists an OEM mounting bracket/s for the two engine/trans control modules? I have the engine and wiring harness; however, I did not get any mounting brackets. Thanks in advance!
Old Feb 26, 2019 | 06:20 PM
B52bombardier1's Avatar
I don't have a TCM but Dirty Dingo made my PCM bracket. The Dirty Dingo bracket is much smaller without all of the bulky plastic but you could go back to almost any junkyard and pick a replacement OEM bracket for very short money.
Rick
Old Feb 26, 2019 | 07:11 PM
RedRascal's Avatar
Thanks Rick! Dirty Dingo is a new potential supplier and I will first try my local "Pull a Part" to see if I can find an OEM bracket that will work. Thanks Again!
