What impact
going to be doing heads and cam swap on the car this weekend and will do control arms, shocks and springs the following.
Really just wondering if the 3/8 is going to be under powered for pulling crank bolt and some of the more rusty bolts on the body for the control arms.
I have a Milwaukee M12 right angle wrench for moving long bolts in and out. That's pretty handy and can't hit with hard torque. The M18 is more sturdy but it's a too large for my liking.
And then I have a Milwaukee M18 fuel impact wrench for the big jobs. Freaking sweet tool! It has pre-programmed modes where you can change how it hits. One of the modes will immediately slow down when the fastener is loosened and walk it out slow. Again, I never try to final tighten a bolt with an impact wrench. You have no clue what it actually tightened to.
+1 on this, I have the 1/2 DeWalt and your just one setting away from doing most anything unless it's a cramped area, #2 setting tightens lugnuts to 95 ft/lb as checked by a torque wrench FYI....... as far as DeWalt vs Milwaukee I will just say this, BOTH are great but I switched from Milwaukee years ago because I got tired of buying their new style battery/tool platform every couple years when all my DeWalt friends kept the same platform for 20, both are fantastic top quality tools but my Dewalt 20V ownership has been considerably less expensive (and I have a lot of cordless tools) than my Milwaukee was.
I still use air a lot because theres just some things battery tools just can't do. Plus, in my job, speed is of the essence.
there are newer versions of the same tool, so just going off a recommendation of brand and size can leave you with a tool that you’re disappointed with...
From my experience, the dewalt batteries pack a bigger punch. But I’m talking about the 20v flex batteries. You’ll need at least a 5ah to be happy with a 1/2” drive impact. That big impact Is good for lug nuts and suspension and steering. But you will NOT want To use it for the rest of the vehicle.
if I had to pick one as my go-to, it’d be the New Version M12 Fuel Milwaukee w/ 3/8” drive. This has crazy break away torque specs for a 3/8” drive tool. Has 3 speeds plus a breakaway setting., but you have to get the ‘new version’ with the short chunky body and the square drive anvil(The old version m12 fuel impacts are garbage in comparison). Or if you want to stick to all the same batteries, the Dewalt 3/8” drive DCF895 impact is the way to go. This was my go-to everyday tool for 5 years and never skipped a beat. You can get the 1/4” hex to socket adapters to use any drive sized sockets(1/4, 3/8 or 1/2”) in literally 2 seconds. The DCF895 had been discontinued by dewalt, but you can still find them easily, still get parts, and it’s a better tool than all the current dewalt impacts. It’s shorter and more compact and the quick release is also one handed and has 3 speeds.
Lastly, the m12 3/8” Milwaukee impact Ratchets are also great mechanics tools and real big time savers. They get in tight spaces, but aren’t that powerful.
the Only thing you will find that a battery powered 1/2” drive impact Won’t be able to handle on an F-body is the pinion nut. But a fresh charge on a 9ah 20v flex battery did the trick for me more than a few times.
Like i said, if you can only afford one right now, get the 3/8” m12 Milwaukee or 1/4” quick release dewalt first. Just have a break away bar handy at your side for the few times that it isn’t up to the task. You will be much happier with the 3/8 and it’ll get use 3 to 4 times as often as any 1/2” would.
