Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Looking at buying mig welder
Old Jul 11, 2022 | 06:28 AM
mdnverz's Avatar
Default Looking at buying mig welder
I am looking at buying mig welder as mine Was stolen it was a Harrington spitfire 200 dc.
Excellent machine but this firm no longer exists, there are plenty other makes though and I would say they are all very similar using same engines and generators .. I have seen one which caught my attention and that is a vanguard powered by propane but is cheaper to run ?
Also I was surprised to see that a 200 amp machine will only weld 8mm max
Thanks for any replies
Old Jul 11, 2022 | 02:27 PM
Jimbo1367's Avatar
I’d check YouTube for brands reviews. Fourney (so) might be one. What kind of money are you looking to spend?
I have a couple of Millers (mig and tig) that I really like.
you can buy a good machine without spending a lot. You just need to do your research. YouTube videos on reviews is good. Try a GOOGLE search too
Old Aug 17, 2022 | 06:07 PM
Old Buzzard's Avatar
It appears he's talking engine powered welders.....
Old Oct 16, 2022 | 11:01 AM
redpill777's Avatar
Default Hitbox
I had an old Lincoln mig 185 that worked great for many years but needed some major electrical work the parts were more than it was worth and needed one pretty quick on a low budget, purchased a hitbox with mig rig and stick, bought an optional 30 foot spool gun for and additional 120$ all total it was about $420 tax and shipping, I just used it on 110 at first and was amazed how well the stick welder worked, very smooth but had to hook up on 220 for the mig to really work properly as well as the tig, I use it a little every week and it is amazing for the price.
https://www.ebay.com/itm/17531859147...mis&media=COPY
Old Oct 16, 2022 | 11:09 AM
bthomas's Avatar
I'm partial to the older miller series with manual *****, like a millermatic 210. The newer inverter and touchscreen stuff doesn't seem to have the same reliability. Too many reports of circuit boards burning up.
Old Oct 16, 2022 | 07:28 PM
LS1 TJ's Avatar
I've had a Miller 211 Auto-Set for 20? years and zero problems. I run it on 110 volt 99% of the time with 0.30 wire. Thicker stuff I switch to 0.35 wire and 220 volt.
