Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Floor jack rebuild kits
Old Mar 22, 2005 | 01:15 AM
SmokingWS6's Avatar
Question Floor jack rebuild kits
I have a Craftsman 3 ton floor jack, looks to be of 70's/80's vintage. It won't jack up fully since its leaked out some fluid. I can't find a specific leak, just leaks around the seals in general. Are there any seal/rebuild kits for these?
When I loosned what appears to be the refill screw,fluid just pours out like its full. How do I refill it? I'm a floor jack noob never had to work on one.
Old Mar 22, 2005 | 03:57 PM
robertbartsch's Avatar
Yeh, I have one Sears lift that did not work well from the box.
Since they are cheap, I just bought a replacement... make sure you use stands before you get under any pile of iron...
Old Mar 22, 2005 | 04:00 PM
white2001s10's Avatar
did you make sure that the fill hole was the highest point in the system?
since any air pockets will rise to the highest point.
Old Mar 22, 2005 | 04:27 PM
SmokingWS6's Avatar
Ahh I'll try standing it on end to fill it up.
I figure its worth rebuilding, their current 3ton jacks are about half the size and strength.
