Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Tim's Valve Spring Tool Now Available
Old Jan 13, 2015 | 05:46 PM
  #941
tnmotown's Avatar
Originally Posted by 2001 SOM WS6 69 GTO
tnmotown,
Our tool was designed to be used when the heads are still on the car so to answer your question YES. Just follow the included instruction and you will be good to go. Make sure to grease the threaded stud really well. Any other questions just let me know.
Thanks,
Tim
Sending you a PM
Old Jan 16, 2015 | 04:27 PM
  #942
tnmotown's Avatar
Got mine in today, everything looks nice and was packaged well.
I'll be using it tomorrow or the next day, so wish me luck lol.
Old Jan 18, 2015 | 10:32 AM
  #943
tnmotown's Avatar
Need help guys,
When doing the air compression in a cylinder to remove the valve springs, do all the remaining spark plugs have to be in?
I'm airing up the cylinder and seems like a big air leak/hissing somewhere. My air compressor keeps turning on to fill up the 60psi I have it set at.
Thanks for your help
Old Jan 18, 2015 | 12:14 PM
  #944
2001 SOM WS6 69 GTO's Avatar
tnmotown,
You will need to rotate the engine by hand some as the hissing sound is air going thru one of your valves in that cylinder as both valve need to be closed to fully compress the cylinder you are working on. I always use a breaker bar and socket and rotate the engine by using the balancer bolt (make sure to remove the breaker bar/socket off the balancer bolt after you rotate the engine to where you need it) It is easiest to rotate the motor when all the spark plugs are removed and NO they do not need to be in the other cylinders. Hope this helps
Tim
Old Jan 19, 2015 | 10:50 AM
  #945
tnmotown's Avatar
tnmotown,
Tim
Thanks Tim for your reply, and I got your email as well.
I wasn't able to check back after I posted, because I just kept on going with the install. The valves held up into place and everything was done in about 3hrs total. Probably could of been done sooner, but the back valves were a tight area and getting the locks to stay together was a pain lol.
It wasn't a very difficult job, but very time consuming. All in all, the car started up and sounds good with the cam
Old Feb 9, 2015 | 11:27 AM
  #946
93M6Formula's Avatar
Payment sent a few minutes ago for an LT1 tool! Can't wait to use it.
Old Feb 9, 2015 | 02:17 PM
  #947
tnmotown's Avatar
It's a nice tool for the price. It wasn't that bad changing out the springs on my ls1, even though the heads were still on the engine and my big hands/fingers made it difficult to reach in the back engine area lol.
Old Feb 18, 2015 | 12:37 PM
  #948
bottomline2000's Avatar
paypal sent for lsx tool.
Old Feb 18, 2015 | 03:51 PM
  #949
Hello Bottonline2000,
I received your payment and have it packaged up and will be shipping it out tomorrow morning via USPS priority mail. I will email you the tracking number so you can follow it.
Thanks,
Tim
Old Feb 28, 2015 | 03:47 AM
  #950
metallicamaster3's Avatar
$35 payment sent to ramair69gto@sbcglobal.net!
Please let me know when you can ship out. Thank you!
Old Mar 4, 2015 | 05:42 PM
  #951
115celi's Avatar
Payment Sent!
Old Mar 7, 2015 | 01:12 AM
  #952
Cmg393's Avatar
Are these tools still available (ls1 valve spring compressor)?
I just got everything together to do a cam swap and need one.
Also how likely am I to break a bolt off in the head by using this?
Old Mar 7, 2015 | 06:05 PM
  #953
Hello, Yes I have plenty in stock ready to ship. I send you a PM with reply's to your questions.
Thanks,
Tim
Old Mar 7, 2015 | 11:11 PM
  #954
Received and went right to work! Worked great, thanks for this excellent tool.
Attachment 723701 Attachment 723702
Old Mar 10, 2015 | 08:24 PM
  #955
charger758's Avatar
Payment sent from runjosh19@hotmail.com. You are in Livonia, I should have just driven over to pick it up
Old Mar 11, 2015 | 02:14 PM
  #956
000000001's Avatar
I need one of these
Old Mar 25, 2015 | 02:52 PM
  #957
fastcars95's Avatar
I got mine today. Thanks very much. Time to get to work
Old Apr 17, 2015 | 07:52 AM
  #958
punkdipo87's Avatar
Default lsx tool
Payment sent for lsx tool thanks
Old Jun 2, 2015 | 08:15 PM
  #959
SDyess's Avatar
How does your tool differ from the ones that compress 2 springs at once. Preparing to do my first in car ls1 cam swap finally.
Old Jun 5, 2015 | 08:30 PM
  #960
supernaturalta's Avatar
Payment sent for an LTX Valve Spring Combo Kit.
