Tim's Valve Spring Tool Now Available
#765
question, which tool should we select if we have an LT1 but are using Beehive valve springs?
i ask because i have tried just about every other valve spring compressor.. and the tabs that push down the retainer are too wide, and slip off the retainer.. i need the tabs to be narrow so this wont happen..
which one do i select?
#768
Used it this past weekend to help a buddy swap out a cam and valve springs.
The tool worked flawlessly and even the back cylinders under the cowl were not a problem. Thanks again Tim for making a nice affordable tool that works!
#773
Sneaky, You sent your PM's to me instead of Tim!
I have been out of town and just returned your last PM.
To answer your question, Tim always has plenty in stock so just follow the directions at the beginning of this thread to send a paypal.
Thanks, John
Thanks, John
#779
Tim always has them in stock.
Yes, they do work on LS-7 heads
Shipping only takes 2-3 days.
Just follow directions at beginning of the thread.
John
John
