Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Tim's Valve Spring Tool Now Available
Old 09-10-2005, 10:07 AM
  #61
ZMAN Z28's Avatar
Originally Posted by Bluehawk27
gto69judge was the originator of the tool, so yeah
He better put a copyright or a patent on it then. Because I know others who have fabricated this tool a few years back also.
Oh yeah I'd like to introduce myself to the board. hehe
1995 blown up Z-28 heads/cam/nitrous
Old 10-01-2005, 08:26 AM
  #62
TAQuickness's Avatar
pm sent
Old 10-05-2005, 03:37 PM
  #63
2001 SOM WS6 69 GTO's Avatar
Default Shipping to Canada
Just to let anyone in Canada know that I will ship to you, and it will cost you an extra $ 5 dollars for a total of $ 35 shipped to your door. The only thing I ask is that the money is sent via PayPal. Thanks
Tim
Old 10-05-2005, 10:26 PM
  #64
Got my tool today. Super fast shipping. Will be using it this weekend. Thanks Tim
Old 10-09-2005, 09:08 AM
  #65
Hey, No problem TAQuickness good luck with your swap
I have several ready to be shipped, just let me know if anyone needs one.
Tim
Old 10-13-2005, 05:24 PM
  #66
Moderator
davered00ss's Avatar
I highly reccomend this tool. I made my own, and went through 6 studs, because they were not high enough quality. Grade 8 studs too. They bent and threads wore off. If I had it to do over I would buy this one.
Old 10-17-2005, 05:31 PM
  #67
tbick's Avatar
i will be replacing the valve springs on my 95 3.4 v6, what would i have to do to use this tool, or will i have to find something else?
Old 10-17-2005, 07:18 PM
  #68
Hi tbick,
To be honest with you I have never worked on a 3.4 V6 so I am not sure exactly how to answer your question. If I had to guess I am thinking that the LT1 valve spring tool that I am about to release in the next week would work but I am again not 100% sure. I would hate to go thru and sell you a tool that will not work. If you have the ability to send me a picture of the valve train I would be able to tell you right away so if you can find a pic send it to me and we can go from there. Sorry I am not able to tell you yes or no but let see if we can find out.
Old 10-17-2005, 11:02 PM
  #69
tbick's Avatar
thanks for the response, ill see what i can do about some pictures. $30 is a good price, i wouldnt be that dissapointed if it didnt work, i just dont want to buy a $100 compressor and for it not to work.
Old 10-18-2005, 12:03 PM
  #70
ninobrn99's Avatar
take it you still have some ready to go right?
Old 10-19-2005, 07:15 PM
  #71
ninobrn99's Avatar
paypal sent...pls let me know when it ships so i can keep an eye out for it
Nino
Old 10-24-2005, 04:11 PM
  #72
ninobrn99's Avatar
edit...thanks for the help!
Nino
Old 10-24-2005, 06:23 PM
  #73
Hi Nino,
I sent an email to you.
Tim
Old 10-24-2005, 09:45 PM
  #74
ninobrn99's Avatar
could you just pm me??
Old 10-25-2005, 02:28 PM
  #75
gto69judge's Avatar
Default Spring Compressor Caution
When using ANY valve spring compressor, a couple of rules must be observed.
As you compress any spring, the space between the coils reduces. When the coils start to touch each other, the spring can no longer be compressed and acts like a solid steel spacer. This is referred to as coil bind or stack height.
If you continue attempting to further compress the spring, something else has to give since the spring can no longer compress. I will list the events that will occur from least damaging to most severe if you attempt to compress springs beyond coil bind. (1) The tool will bend, preventing any damage to your engines parts. (2) The nut or stud will strip, still preventing damage to your engines parts. Now imagine what would happen if we used a bulletproof super strong tool, nut, and stud. (3) The only thing left to give would be the threaded rocker pedestal on the head which you never want to see damaged.
Tim's Tool is designed with these factors considered. The thickness and characteristics of the tool's body as well as the tensile strength and hardness of the stud and nut were considered in it's design. No problems have been encountered with Tim's Tool when properly used on hundreds of spring swaps with all types of springs including triple springs on many different types of engines.
Spring Compressor Rules:
(1)Always lubricate all moving parts with a heavy weight oil or grease.
(2)Place a socket over the valve retainer of each spring and tap it with a hammer to loosen the keepers fron the valve retainer.
(3)Align the tool to apply even force on the spring retainer and make sure that the tool does not contact the keepers.
(4)Tighten the tool by hand only. DO NOT USE AN IMPACT WRENCH, AIR RACHET, OR POWER ASSISTING DEVICE.
(5)If any sudden increase in tightening torque is noticed, something must be binding. Look for the source of interference.
(6) NEVER tighten past the point of coil bind.
Several people have reported that they have used one of Tim's Tool for more than 20 spring swaps without a problem and it is still working perfectly.
Old 10-26-2005, 08:52 AM
  #76
Bill Bowling's Avatar
Originally Posted by AdamSS
Well, I must say Tim's Tool is simply awesome !
I've started my cam swap yesterday, and today I just swapped my springs for new Patriot Golds.
Tim's tool worked like a charm. Spring compressed enough to lock the new keepers, and made the "spring/retainer" assembly centered around the valve stem very nicely. Oh - and I used the TDC method to keep the valves up.
Again, the best thing about Tim's tool, is that you have a lot of clearance, even under the cowl. I had no problem with the rear ones at all.
I highly recommend this tool.
Here's a couple pics from today:
Looks just like the Larry Tool I bought a few months ago. I paid $40+ for mine.
Bill
Old 11-03-2005, 11:56 AM
  #77
tylerdj's Avatar
I'll take one...paypal sent
Old 11-10-2005, 06:15 PM
  #78
ssheets's Avatar
Great. I'll 16 if them
Old 11-17-2005, 07:07 PM
  #79
I have plenty of tools in stock ready to ship. Let me know if I can help anyone out.
Tim
Old 11-17-2005, 09:46 PM
  #80
BlkSS1755's Avatar
just made my order.. thanks Tim!
Quick Reply: Tim's Valve Spring Tool Now Available
