Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Welding the exhaust...
Old Jun 7, 2005 | 07:49 PM
blind527's Avatar
Default Welding the exhaust...
So yeah, I plan on welding with a line? welder? My dads friend who is a pro welder is gonna do it. I have Jet Hot LT's, into a Jet Hot ORY and a cutout. Since its coated, will there be any problems welding?
On the cutout I want to spray this heat treated coating on it. Should I wait till after the cutout is welded into the y pipe and i pipe, or is it ok if it's painted? My dad told me if I sprayed it with this protectant it may not weld because it needs to be the bare metal.
Old Jun 7, 2005 | 07:52 PM
Louis's Avatar
Bare metal, and grind the coating off where you are going to weld. Non contaminated material to work with is best when welding.
Old Jun 7, 2005 | 08:00 PM
blind527's Avatar
Do you mean grind the coating off the Jet Hot coated y pipe? Should I just sand down the end till most of the coating is off?
Old Jun 7, 2005 | 09:38 PM
Cummins's Avatar
the more coating you get off where your going to weld, the easier and better the weld will be
Old Jun 8, 2005 | 09:48 AM
robertbartsch's Avatar
Some people say to disconnect the battery and computer if you are arc welding. Since I'm not an expert on this one, ask others here...
Old Jun 8, 2005 | 10:44 AM
jdustu's Avatar
definetly disconnect the battery when welding on the car......
