question about gas mig welding
another thing that i am noticing is that the tip and the wire are starting to get welded together and these are all problems that i never had without gas...am i doing something wrong? too much gas? not enough gas?
What is a suggested pressure to use coming out of the bottle...
Thanks
Louie
For the gas, hopefully your regulator has two gauges. One for tank pressure and one for output CFM. Adjust the CFM to between 20 - 25 CFM. Make sure to weld where there is little or no wind.
Couple of thoughts on wire sticking to the tip: 1. The wire may not be clean enough or lubed. Ask your local welding store for some lube pads (look like felt with an attachment clip) and lube oil. These pads both clean the wire and add a little lube - this is a good idea even if it does not solve your immediate problem. 2. Your wire speed may need to be a little higher 3. Adjust the "stick-out", should be about 3/8" out of the nozzle (is it burning back?). 4. Check the pressure on the drive rollers (too little and the wire won't feed at a constant rate, too much and the wire can be flattened).
Hope this helps.
there are two guages i am not sure what i had the CFMs set at as i was trying to adjust it to work better for me. Increasing the wire speed did help my problem to an extent...
But i will definately try all of the suggestions.
Thanks
Louie
Thanks guys!
i cant wait til i have to weld something now.
Louie
the other gauge is your CFM out put - basically how much gas your welding tip is putting out.
