Need clutch cable disconnect tool
But if you're just pulling the trans, don't disconnect the line. Remove the transmission to bellhousing bolts, slide the tranny back about 3", and then use a 10mm wrench to remove the 2 bolts that hold the slave to the faceplate of the transmission (gearwrenches rock on these bolts, but regular wrenches work fine). Easy, and you don't have to bleed it afterwards since you didn't disconnect it.
