Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Cleaning epoxy from plastic
Old Jul 26, 2006 | 06:13 PM
BizZzatch350's Avatar
Moderator
Default Cleaning epoxy from plastic
Need to clean off old epoxy from plastc head light motor, whats the best stuff to use to get it off?
Old Jul 30, 2006 | 02:51 AM
ACW's Avatar
ACW
I've seen suggestions of acetone, engine degreaser (ex: Simple Green, Castrol Super Clean), Goof-Off, brake fluid, and Pine-Sol. Pine-Sol does damage some plastics, so I'd try the other stuff before it.
Old Aug 3, 2006 | 04:25 AM
Silverback's Avatar
Most epoxy’s once cured are much more durable then plastics… I’d suggest mechanical means and then polishing up the plastic when you’re done. Any chemical that will remove the epoxy will at the very least make the plastic brittle.
