Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Engine Lifting
Old Jul 27, 2006 | 04:43 PM
unclemeat's Avatar
Default Engine Lifting
I have a question:
I got an LS! with tranny attached. What or where are the mounting points to lift it??? Its on the ground right now.
Old Jul 27, 2006 | 05:40 PM
leonpiper69's Avatar
i take 2 bolt out of the bellhousing and drap a chain over the motor diagonally , just make sure you leave sone slack in it so it doesnt put any presure on the in ake or lines. then run the bolt through the chain till it bottoms out. i use the lower holes on the heads. pass side in the back. i use the lower unses so cuz it looks stronger there than higher up(more material around the hole) hope this helps.
Old Jul 28, 2006 | 07:53 AM
2002blackZ's Avatar
If you use the bolt holes on the back of both heads where the picture above indicates it will balance out pretty well with the tranny attach. If no tranny, lift as described above.
Old Sep 10, 2006 | 10:54 PM
unclemeat's Avatar
thanks for the ideas!!
