Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
hydraulic tool?
Old Oct 22, 2006 | 02:55 PM
blackhawk J's Avatar
Default hydraulic tool?
I am pulling the transmission out to change the clutch. This is my first time doing one of these jobs so I need a tool to pull out the hydraulic connection. Can some one tell me how the fitting works and maybe a picture of a tool for it or where to get it. I went to my local advanced auto and the guy didnt know what I needed.
thanks guys
Old Oct 23, 2006 | 10:17 AM
BillS's Avatar
the GM tool is just a flat peice of metal with a U-shaped notch in on end.
To get it off easily just crack the bleeder valve, Then use 2 flat blade screwdrivers to push the white collar on the fitting into the fitting( kind of a reverse air fitting) the collar releases the locking tabs and then the two parts will seperate. I have been able to do it with my fingers if the bleeder is open.
Also open the bleeder when reconnecting and it is much easier
