Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
difference between argon and oxygen tanks?
Old Jan 25, 2007 | 10:37 AM
RyRy's Avatar
Default difference between argon and oxygen tanks?
I was wondering if there is a difference between oxygen tanks and argon tanks for welding. If I got an oxygen tank would I be able to get it filled with argon for mig? I found a guy willing to give me an oxygen tank for $40 but I want to use if for argon. If anyone knows could you jsut give me a heads up? Thanks...
Old Jan 25, 2007 | 01:19 PM
the.erinyes's Avatar
Same tanks, different label. I would check with your supplier though, since having Oxygen in the tank previously may contaminate the Argon, since you are trying to displace the oxygen around the weld with Argon.
Old Jan 25, 2007 | 03:29 PM
RyRy's Avatar
good call... Thanks for the advice...
Old Jan 25, 2007 | 09:23 PM
xfactor_pitbulls's Avatar
Argon in either 75% or 100% is an anti-oxygen and will render oxygen useless. Doesnt really matter for two reasons though. First is that they purge and vaccum any new tank that is not labeled by the supply house. Secondly, you are usually not getting your bottle back. You just exchange for one of theirs.
