Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Tool Identification Guide
Old Dec 7, 2002 | 06:32 AM
HOSS99's Avatar
Default Tool Identification Guide
I'm not sure of the correct forum to post this in, but I thought many would enjoy this.
HAMMER: Originally employed as a weapon of war, the hammer nowadays is
used as a divining rod to locate expensive parts not far from the object we
are trying to hit.
MECHANIC'S KNIFE: Used to open and slice through the contents of
cardboard cartons delivered to your front door; works particularly well on
boxes containing tonneaus, soft tops, and leather upholstery kits.
HAND ELECTRIC DRILL: Normally used for spinning steel Pop rivets in
their holes until you die of old age, but it also works great for drilling
mounting holes in fenders just above the brake line that goes to the rear
wheel.
PLIERS: An adjustable tool used to round off bolt heads.
CRESCENT WRENCH: See PLIERS
HACKSAW: One of a family of cutting tools built on the Ouija board
principle. It transforms human energy into a crooked, unpredictable motion,
and the more you attempt to influence its course, the more dismal your future
becomes.
AVIATION METAL SNIPS: See hacksaw.
VISE-GRIPS: Used to round off bolt heads. If nothing else is available,
they can also be used to rapidly transfer intense welding heat to the palm of
your hand.
OXYACETYLENE TORCH: Used almost entirely for lighting various flammable
objects in your garage on fire. Also handy for igniting the grease inside a
brake drum you're trying to get the bearing race out of.
WHITWORTH SOCKETS: Once used for working on older British cars and
motorcycles, they are now used mainly for impersonating that 9/16 or 1/2
socket you've been searching for the last 15 minutes.
DRILL PRESS: A tall upright machine useful for suddenly snatching flat
metal bar stock out of your hands so that it smacks you in the chest and
flings your beer across the room, splattering it against that freshly painted
part you were drying.
WIRE BRUSH WHEEL: Cleans rust off old bolts and then throws them
somewhere under the workbench with the speed of light. Also removes
fingerprint whorls and hard-earned guitar string calluses in about the time
it takes you to say, "Ouch...."
HYDRAULIC FLOOR JACK: A device used for raising a vehicle off of the
ground. When RAISING - The first stopping point will ALWAYS be 1/2 inch below
the top of the Jack Stand. When LOWERING - The stopping point of the Jack
will ALWAYS be 1/2 inch above the height needed to remove the Jack.
EIGHT-FOOT LONG DOUGLAS FIR 2X4: Used as a long lever with crushable
ends.
TWEEZERS: A tool for removing wood splinters caused by the above.
PHONE: Tool for calling your neighbor to see if he has another
hydraulic floor jack.
GASKET SCRAPER: Theoretically useful as a sandwich tool for spreading
mayonnaise or peanut butter. Used mainly for getting dog-doo off your boot.
PUTTY KNIFE: A shorter and wider version of a GASKET SCRAPER (above).
Who the heck uses putty anymore anyway ?
E-Z OUT BOLT AND STUD EXTRACTOR: A tool that snaps off in bolt holes
and is ten times harder than any known center punch or drill bit.
TIMING LIGHT: A stroboscopic instrument for illuminating the grease
that has built up on a harmonic balancer.
TWO-TON HYDRAULIC ENGINE HOIST: A handy tool for testing the tensile
strength of ground straps and fuel lines you may have forgotten to
disconnect.
1/2 x 16-INCH SCREWDRIVER: A large motor mount prying tool that
inexplicably has an accurately machined screwdriver tip on the end without
the handle.
PHILLIPS SCREWDRIVER: Normally used as a non-drifting drift to ALMOST
align motor-mount holes. Can also be used, as the name implies, to round off
Phillips screw heads.
BATTERY ELECTROLYTE TESTER: A handy tool for transferring sulfuric acid
from a car battery to the inside of your toolbox after determining that your
battery is dead as a doornail, just as you thought.
TROUBLE LIGHT: The mechanic's own tanning booth. Accurately called a
"drop" light. It is a good source of vitamin D, "the sunshine vitamin," which
is not otherwise found under automobiles at night. Health benefits aside, its
main purpose is to consume 60-watt light bulbs at about the same rate that
105-mm howitzer shells might be used during, say, the first few hours of the
Battle of the Bulge. More often dark than light, its name is somewhat
misleading. Makes a tinkling sound and a whisp of smoke when splashed with
radiator coolant.
AIR COMPRESSOR: A machine that takes energy produced in a coal-burning
power plant 200 miles away and transforms it into compressed air that travels
by hose to a Chicago Pneumatic impact wrench that grips rusty bolts last
tightened 50 years ago by someone in Michigan or England and twists them off.
PRY BAR: A tool used to crumple the metal surrounding that clip or
bracket you needed to remove in order to replace a 50 cent part.
TUBING CUTTER: A very accurate tool used to cut brake and fuel lines
exactly 1/2 inch too short.
6-FOOT STEEL TAPE: A long slender steel ribbon with inch marks. Steel
tapes ALWAYS break-away and bend downwards just before you reach the point to
which you are measuring.
BEAM-TYPE TORQUE WRENCH: A long tool used for precisely tightening nuts
and bolts. Chief characteristic of using = The handle will ALWAYS contact
firewall or fender-well just BEFORE the required torque value is reached.
CLICK-TYPE TORQUE WRENCH: A long tool used for precisely tightening
nuts and bolts. May also be used as a very accurate and expensive BREAKER BAR
BREAKER BAR: A long tool for loosening and tightning nuts and bolts.
May substitute for TORQUE WRENCH. When used to tighten nuts and bolts, the
rule of thumb is "Thighten Until It Strips - Then Back It Off 1/4 Turn".
