Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
flywheel locking tool
Old Jun 9, 2007 | 11:07 PM
DSRCAM's Avatar
Default flywheel locking tool
ok i need a flywheel locking tool, where can i get one cuz im doing a cam swap real soon please get back thanks...
Old Jun 11, 2007 | 06:40 AM
Shinigami2x4's Avatar
Check autozone rent parts - also harbor frieght has them. Or you could go old school with a screw driver and a friend and tons of curse words and lost tools.
Old Jun 11, 2007 | 08:56 AM
RGKSR's Avatar
Default Flywheel Locking Tool
How about I lend you mine?
Let me know when you need it and I'll mail it to you. Send it back when your done!
Bob K.
Old Jun 19, 2007 | 08:15 PM
76LS1BIRD's Avatar
Restricted User
They also have tools thet hold the pulley from turning.
Dale
Old Jun 19, 2007 | 09:36 PM
02NBMFormula's Avatar
Dale
got a link for this?
Old Jun 19, 2007 | 10:48 PM
SS SLP2's Avatar
GM dealership has bolt about 4-6.00
go to http://www.aspraceing.com,then go to belt section and get belt #'s go to local parts supplier and they can cross to a belt which they srock ( I like the goodyear gater back belts ) think about 20.00 each , I will post some info below hope some of it helps :::
REmove the small 2 in round plug on bottom of bellhouseing insert a BIg screw driver or pry bar into the teeth of fly wheel ( you will need a freind to help) may need to insert one behind the flap behind the starter also >>>( NO need to remove the starter) OR you may order the special tool from GM which will bolt to block which will hold the fly wheel
get a big peice of pipe to use as cheater on on ratchet or breaker bar ( some say bind bar and bump starter to loose crank bolt ( I WOULD NEVER DO THIS )
Will need a 3 leg puller that will pull from the inside ( never from outside ) of stock pulley (may rent from local past supplier )
when ready to re install I get two new crank bolts from dealer and weld a 5/8 x 4 in bolt to head of one ,
( will need to grind down the washer on stock bolt so that it will fit threw the pulley) screw the welded crank bolt in to crank slide a socket( one that will just fit inside the pulley- to use as a guide to start pulley stright ) over the welded 5/8 bolt ,use this to pull the puller back on this way you are not puting much strain on the threads inside the crank Lubricate and mount the ASP pulley onto the snout. Once it is pressed close to flush ( about 1/8 being flush) then install old bolt and tighten it to 240 ft. lbs. or until it is completely seated on the crank snout. Afterwards, REMOVE THE STOCK BOLT and replace it with the NEW CRANK BOLT. You will tighten the NEW bolt to 37 ft. lbs. and then turn it an >>additonal 120 degrees.<<<
hope this helps Johnny
ps:: I install a new seal any time I remove a pulley($10.00 and 10 minutes now is better than haveing a leak and haveing to remve pulley again
SORRY about the rambling, but you may like to make your toolas it is quite easy
may make a tool to hold flywheel
hope the drawing of tool is understandable
use a 1/8 x 2 flat bar about 12 in long insert into flywheel threw the round hole in botton of bellhouseing ,the notch in side will hold tool in place
PS: THE DRAWING DOES NOT SHOW UP CORRECT ,it should be about 2 in wide all the way down
Old Jun 20, 2007 | 07:48 PM
Doc's Avatar
Doc
http://www.spxkentmoore.com/
