Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Welding question
Old Aug 1, 2007 | 08:19 PM
lovin myls1's Avatar
Default Welding question
When the muffler shop installed my cat back,they put small welds(maybe an inch long) on the pipe joints.Soon I want to install my headers and plan on doing them myself.Can i break the weld or grind it off without injuring the pipes of the catback?
Old Aug 5, 2007 | 05:24 PM
toplessHO's Avatar
If you get a good pipe cutter you can cut about 1/4 inch away from the welds
all the way around it.
Kinda like a big tubing cutter. then just slide the pipe off.
Old Aug 5, 2007 | 09:16 PM
Hey, thats an idea,Thanks!
Old Aug 5, 2007 | 09:39 PM
bgblockelcamino's Avatar
i have used a cutoff wheel and carefully cut welds enough to break the pipe/ exhaust free. if you are careful you can cut it and be able to slide the pipe back on when you are done
Old Aug 6, 2007 | 05:33 AM
Glad to hear that!I'm going to try to cut or grind weld off if I can first,then cut pipe if I have to.Starting my headers this very morning!
