Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Advise on cutting metal sheet
Old Sep 15, 2007 | 08:39 PM
Vertigo's Avatar
Default Advise on cutting metal sheet
I need to cut a template out of a flat 1/3" sheet of metal. I am not sure what type of metal i would like to use but it needs to be fairly strong. For example could i just use a blow torch to cut through it? A cutting wheel? I am not TOO concerned with cutting it exactly accurate as i can alway file down to a straight line or whatever.
Thanks!
btw i have no welding or cutting so whatever is the cheapest would be great!
Old Sep 16, 2007 | 09:37 PM
braap's Avatar
Unless you're up for purchasing a torch or plasma cutter, your only bet for doing it at home will be abrasive cutting. You can purchase a 4" electric grinder from Harbour Freight or Northern Tool for the cheap. Set it up with a 4" cut off wheel and you're in business. Just be sure to wear thick leather gloves and a face shield!
Good luck.
Old Sep 17, 2007 | 08:15 PM
Vertigo's Avatar
Good luck.
How much is a torch? also, could you send me a link to the 4" electric grinder?
Thanks!
Old Sep 17, 2007 | 08:31 PM
99camarosupersport's Avatar
Find you a local metal shop perhaps, they could laser cut it for a decent price I bet. ~50$
Anything heavier than 22ga is going to be hard to cut by shears, how thick you talkin?
