Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Tire / Wheel Storage Ideas
Old Oct 10, 2007 | 10:51 AM
9T7 Trans Am's Avatar
Default Tire / Wheel Storage Ideas
What do you use to store your wheels and tires besides throwing them in a corner? I am trying to get them up off the floor so I have more workbench space. Found this for $130:
http://www.tirerack.com/accessories/...orage_rack.jsp
Any alternative ideas / products that you know of?
Old Oct 10, 2007 | 01:56 PM
K99Raptor's Avatar
That's a pretty cool set up. I might have to get me one of these.
If you can weld, you could probably make your own. Or out of wood.
Old Oct 10, 2007 | 03:33 PM
tim99ws6's Avatar
Yep,
I just had one made out of wood and it's integrated into my big-**** workbench at my house. I'm not sure if you've been to my house or not Kermit, but it's a solid setup. The only thing that i don't like about mine, or the one pictured above is that you can't sit soft tires(i.e. slicks) on them, as they tend to warp them if they sit too long...
Old Oct 10, 2007 | 07:36 PM
romoranger's Avatar
well, whats a decent way to hang slicks so they don't warp? i keep my tires in the shed in my backyard and i can't open the door anymore.
Old Oct 11, 2007 | 09:58 AM
mitchntx's Avatar
Mounted or unmounted?
I built a rolling tire cart that can hold 3 full sets of tires. I made it out of 1" square tubing and used 4" casters on it ... 2 stationary and 2 that swivel. I added a couple sections of sheet metal and stack my jack stands on the cart to get them out of the way and so I would always be able to find them.
I put my road racing slicks on it and se now warpage. Maybe the RR slick's heavier sidewall keeps that from happening?
If you keep the thinner sidewall slicks mounted, just ari them up to 30psi and they should stay in place.
If that doesn't work, then span the bottom rods with some masonite, put the tire on the masonite and bungee across the front to keep the tires from rolling off the rack.
If that doesn't work, maybe buy a cheap garden hose hanger and trim it to work.
Old Oct 15, 2007 | 01:46 AM
VETTEX2's Avatar
Wink
I made my own tire rack, and roof rack
Once you have a mig, you just make the stuff yourself
