Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
JPR cam install Tool
Old Oct 25, 2007 | 10:11 PM
veloxetmortifer's Avatar
Default JPR cam install Tool
Does anybody have any links that show me how this tool is used? Any info will be greatly appreciated.
Old Oct 25, 2007 | 10:20 PM
corvet786c's Avatar
My mechanic bought these for my cam install. Go to ls1howto.com under cam install. They show u how to do it. Tools are marked L for left and R for right. They work great and dont have to worry about lifters falling.
Old Oct 25, 2007 | 11:44 PM
Awesome link. I really appreciate it.
Old Oct 28, 2007 | 09:32 PM
CETA_TransAm's Avatar
u can go to walmart and buy wooden dowels for like 4 bucks and work just as good
Old Oct 29, 2007 | 12:31 AM
Hennytime's Avatar
home depot and get some metal dowels. 0% chance of breaking. ive heard of one or two wooden ones breaking. small chance, but best not to take any. the metal ones will run you around 10 bucks
Old Oct 29, 2007 | 01:04 PM
good idea still cheaper i forgot what size ur suppose to get ?
Old Oct 29, 2007 | 05:59 PM
98_Formula's Avatar
wow good info here, subscribed.
Old Oct 31, 2007 | 12:43 PM
loyolacub68's Avatar
Yeah what is the size on those metal dowels? That would be quite a difference in price compared to the ones from Thunder.
Old Oct 31, 2007 | 12:52 PM
i got it written down some where but i cant find it if i find it ill post it up
i thinking somewhere around 3/8 or something
Old Nov 2, 2007 | 09:00 AM
Thanks for all the info. I greatly appreciate it. If anyone can tell me the size of the dowels that would be great. Thanks again.
Old Nov 3, 2007 | 12:21 PM
bhop42's Avatar
I would like to know also.
Old Nov 3, 2007 | 12:47 PM
98RedZone's Avatar
they are 5/16 in diameter. I think I bought 3' and cut it in half.
Old Nov 4, 2007 | 09:24 PM
hi officer's Avatar
i did three cam installs using wooden dowels. i have still had lifters that weren't "locked in" and i had to worry about. i bought the right tool and it locks them in and its worry free.
Old Nov 4, 2007 | 10:06 PM
Steve Bryant's Avatar
LS1 Tech Veteran
Here's a picture that I took a while back to help illustrate what the JPR tool does versus the rod. I bought a half inch diameter aluminum rod and cut it in two planes (similar to the JRP Tool). I made a pair of these and they seem to work just fine. I chose the dimensions so that the valve lifter would be held up in place as much as possible but still have enough clearance to insert the rods and not get stuck. The overall thickness is about 5/16" against the lifter, but compared to a 5/16" rod, the lifter is held about an eighth of an inch farther away from the cam. This is where the JPR Tool probably does a better job than the rod. I've also used the 16 pen magnet trick and that works fairly well too, but it's a pain to clamp all of the magnets in place and they are fairly expensive too.
I plan to retake this photo sometime, because I'm not pleased with the lighting and angle/perspective of the camera.
Steve
Old Nov 11, 2007 | 08:11 PM
scites's Avatar
****!!! i went to home depo today and bought 3/16 rod for the cam swap..guess im going back in the morning..should the 5/16 dowels be swuare or round? or does it not matter? thanks,Tom
Old Nov 11, 2007 | 09:16 PM
JGKadell's Avatar
Why would anyone take the chance of using wood? There is a good chance of dirt or wood particles will get in the engine.
Old Nov 12, 2007 | 05:56 AM
98RedZone's Avatar
I used round
Old Nov 28, 2007 | 12:11 AM
steelwire's Avatar
NON-SPONSOR LINKS REMOVED
