Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
tool to keep crank pulley from spinning?
Old Nov 3, 2007 | 09:08 AM
santiago's Avatar
Default tool to keep crank pulley from spinning?
tryin to torque my pulley down and the pulley just keeps spinning its in gear with the e brake on and the pulley wants to turn the tires over if i pull to hard.
is there a tool for this?
Old Nov 3, 2007 | 09:15 PM
SVT WUT 7's Avatar
Yes, chain wrench.
Old Nov 3, 2007 | 10:03 PM
WE TODD DID's Avatar
impact gun
Old Nov 3, 2007 | 11:44 PM
santiago's Avatar
Originally Posted by SVT WUT 7
Yes, chain wrench.
wont it ruin the part where the belt sits on though?
Old Nov 4, 2007 | 04:59 PM
SVT WUT 7's Avatar
Use it all the time at work and I've never hurt a pulley.
Old Nov 4, 2007 | 10:24 PM
santiago's Avatar
im out of options chain wrench it is
Old Nov 20, 2007 | 08:26 PM
01ssreda4's Avatar
summit has a tool to BOLT to the motor to keep it from spinning, kent moore has one too. i dont like the idea of a chain wrench, not up against 240 ft/lbs.
Old Nov 22, 2007 | 11:08 AM
DONAIMIAN's Avatar
I bought the kent moore tool. It was brand new off eBay for like 35 bucks. Same tool used by the dealership to lock the flywheel in place.
Old Nov 22, 2007 | 02:01 PM
Jimmy P's Avatar
Best way is to lock the flywheel in place.
Old Nov 22, 2007 | 08:21 PM
Loadre's Avatar
Big *** screwdriver on the flywheel.
Old Nov 22, 2007 | 09:38 PM
LS1Silverado05's Avatar
Originally Posted by WE TODD DID
impact gun
Im guessing this is a BAD idea on an LS1...how are you going to torque or degree?
Old Nov 23, 2007 | 12:27 PM
bczee's Avatar
Try these.. They are designed to lock up the crank from spining
• Summit Racing #SME-906008 (holds the pulley)
• KENT MOORE J-42386-A Flywheel Holding Tool
Old Nov 23, 2007 | 12:32 PM
LivingCanvas's Avatar
Are you sure your e brake works very well? I just did this about 2 weeks ago, and my car stayed still, even when pulling on the bolt with a breaker bar+pipe extension
Old Nov 28, 2007 | 12:14 AM
steelwire's Avatar
NON-SPONSOR LINKS REMOVED
