Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Fabricating -AN Hose
Old Jan 9, 2008 | 07:52 PM
NoRice's Avatar
Originally Posted by SilverSmoke
Where are you guys getting the braided hoses and AN fittings to do this custom work?
Brown & Miller Racing Solutions :o wayyyyyyyyyyyyy pricey
jegs/summit have it but if you dont know what you are doing you could get lost in a hurry and end up with a bunch of fitting and hose that dont work
Old Jan 9, 2008 | 08:58 PM
mrdragster1970's Avatar
6 & 8 Second Club
Design your system in advance. Make notes, look at all the fitting styles, look at other cars, ask ?? ect ect.
I would rather buy 1 more expensive fitting than 2 that are cheaper in total.
Not trying to cause an issue. I have never had a line fray with a cut off wheel that was taped. Especially fiber tape.
I have had a few screw up with a chisel, but that was only bigger hose, -10 & -12.
In twenty plus years, 4 cars & many friends, I've done 2-3 fittings.
Old Jan 9, 2008 | 11:19 PM
Mr. B's Avatar
anplumbing.com or Behrents Speed Shop in Florida NY
Old Jan 9, 2008 | 11:22 PM
Nitro Dave's Nitrous Outlet's Avatar
Go to Home depot and get a 15.00 pair of cable cutters with round cut blades. It will work great..
We use them as well as a Sheer here at the shop.
Dave
Old Jan 15, 2008 | 09:18 AM
Fireball's Avatar
what about these?
http://store.summitracing.com/partde...5&autoview=sku
Old Jan 15, 2008 | 09:33 AM
FASTFATBOY's Avatar
A local speed shop sells this stuff, I have some of it on my car...works good. Whats neat about this stuff, is on their 90*, 45* type stuff....sometimes when you make braided line the fitting is not "clocked" right. These fittings will swivel or rotate after they are made up.
http://www.fragolaperformancesystems.com/index.html
David
Old Jan 15, 2008 | 10:02 AM
JMBLOWNWS6's Avatar
I built my whole car and use alot of AN fittings. I use electrical tape and a air tool with a cut off wheel. Works great.
Old Jan 15, 2008 | 10:33 AM
6 & 8 Second Club
Originally Posted by Fireball
WOW, the last ones I saw were over $100. If they're not cheap crap, that's something to try.
Still like my cut off wheel & fiber tape. Never had a fray.
Old Jan 15, 2008 | 12:09 PM
mitchntx's Avatar
I use a chop saw. I have to be very dilligent about cleaning out the hose of any debris after I finish the assembly.
As noted above, using the swivel design fitting, like from Aeroquip, makes hose fitting a lot easier.
FWIW ... eBay has a lot of Aeroquip fitting being sold in lots. It's a cheap way to get what you need.
Old Jan 15, 2008 | 06:56 PM
b00sted's Avatar
I use a dremel with a cutoff wheel. I've never had an issue with fraying, if you do you're doing it wrong. I use a few wraps of electrical tape, and then slowly cut through the braided stainless first. Then I zip right through the rubber...Leaves a PERFECT edge every time. The fitting nut goes right on.
And no bloody fingers.
Old Jan 15, 2008 | 08:32 PM
Dskeet6's Avatar
hey that guy cheated on the Dash 12 cut.......... he flipped it around to where he didnt cut with the chisel....... haha jk seems like it works well.... but seriously he flipped it around
Old Jan 15, 2008 | 09:19 PM
  #32
lethal93ta's Avatar
fiber tape and a chop saw here. never had any problems with frays.
Old Jan 16, 2008 | 03:14 AM
  #33
wolfy's Avatar
that's the key. fiber tape works better than the electrical, although i've been able to make electrical tape to work as long as i don't use more than 3 wraps and i get it wrapped tighter than frog *****...
Old Jan 16, 2008 | 07:58 AM
  #34
MIGHTYMOUSE's Avatar
the summit cutters are fast and work fine WITHOUT TAPE for sizes up to -10. over that they dont fit in the cutters.
the way the blades close around it actually bends the tips of the braiding in a little bit
the tape is way ugly showing under the fitting.
Old Jan 16, 2008 | 08:25 AM
  #35
JMBLOWNWS6's Avatar
I take the tape off!
Old Jan 16, 2008 | 11:45 PM
  #36
wolfy's Avatar
yup, no need for it after you cut, and it just gets in the way when you push the hose into the fitting.
Old Jan 20, 2008 | 11:01 AM
  #37
Mr. B's Avatar
Finally finished the project and I used the Cable Cutters, which didn't work well. Re-did it with a Dremel and cut-off wheel, nice and slow with a piece of electrical tape- perfect!
I got the chisel, but couldn't find a block of aluminum and I didn't want to buy a grinder to sharpen the chisel yet.
Old Jan 28, 2008 | 09:28 AM
  #38
Mr. B's Avatar
I finally finished the project that required the fabrication of -AN lines. It is a remote filter adapter, and remote block adapter to eliminate a leaky oil cooler on a Cobra:
http://mysite.verizon.net/vzex5rf3/misterb/
